Replacing fluorescent ballast | on ElectriciansForums
Discuss Replacing fluorescent ballast in the UK Electrical Forum area at ElectriciansForums.net
jsking
Ohio
I was replacing a fluorescent ballast for a single four foot T8 fixture. The ballast that I bought on line had very short power leads that would not reach the power lines from the ceiling. I spliced an 8" extension on to each of the black and white wires, using wire nuts. Being that this is all contained in the metal housing of the fixture, is this ok to do? In retrospect, I probably should have drilled two new holes and moved the ballast closer to the leads from the ceiling, but now I have cut the wires to the tombstone too short. Thanks for any assistance on this.
Reply to Replacing fluorescent ballast in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
