Replacing small connector on wires | on ElectriciansForums
Discuss Replacing small connector on wires in the UK Electrical Forum area at ElectriciansForums.net
Norway
[FONT=arial, sans-serif]Hey!
[/FONT]
I have a PSP GO! (Playstation Portable). I'm thinking of buying a replacement battery for mine since it's battery is starting to get old. Apparently, the one I'm going to buy does not come with the little plastic connector at the end of the three cables coming out of the battery!
I have one attached to my old battery right now, of course, so what I'm wondering about is if it is easy for a guy who knows nothing of electronics to switch that plastic connector to the new battery without fear of damaging something?
The replacement battery:
http://img.dxcdn.com/productimages/sku_145256_1.jpg
The original battery: http://1.bp.blogspot.com/-x-pA28BN9Jk/TnvTRaRCqhI/AAAAAAAAAEQ/OUmqGL0p_Jc/s1600/2.jpg
In advance, thanks!
For a beginner its not easy.
Can you do it? Depends on your level of competence.
A smattering of fear is always good to prevent overconfidence.
What are your electronices / electrical skills? Have you, say, replaced a BT point or wired CAT 5 cables?
scrounge a bit of telephone/cat5/alarm cable and practice soldering. use a small iron, no more than 25watts. once you have mastered it without melting too much insulation you're good to go to the real stuff.
Reply to Replacing small connector on wires in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
