Replacing storage heater | on ElectriciansForums
Discuss Replacing storage heater in the UK Electrical Forum area at ElectriciansForums.net
codger
United Kingdom
Good morning chaps. Needing some guidance if poss. Looking to replace an existing storage heater in a living room with a panel heater, but looking for something which will give max heat but with max efficiency too. The room is 5m x 5m x 2.5m. Thinking 2.5/3kW possibly, or equivalent.
Can anyone recommend one please...? Thanks in advance.
[ElectriciansForums.net] Replacing storage heater
:D:D:D
Murdoch, sorry. Was just having a laugh. The room is 5m x 5m. Usual height (2.4m?). The flat is at the top of a block of flats, flat roof, 3 outside walls. Concrete floor with a floating floor on the top.
I saw a formula on one site which said to take the floor area and multiply it by 10 to give you an ideal wattage of heater. This would make it 250W. Clearly, that's wrong.
There is currently one 13A spur there with a timed supply which it's intended, will be changed to a 24hr supply.
Reply to Replacing storage heater in the UK Electrical Forum area at ElectriciansForums.net
How did it go?
