Replacing switch on a domestic heater - DIY question | on ElectriciansForums
Discuss Replacing switch on a domestic heater - DIY question in the Domestic Electrician Forum area at ElectriciansForums.net
Birmingham
Hi. I want to replace a faulty switch on a heater circuit but need some advice - photo of circuit attached. Heater has 2 simple on/off switches - one turns a 1Kw circuit of heaters on, the other a 1.5kw circuit of heaters on, both can be on separately or together to give a possible 3 levels of heat. There is also a variable thermostat to change the output setting. One of the switches no longer works but the replacement switch I have has only 2 pins on it, the existing switches have 3. I'm wondering if the live wires on the first switch in the diagram (pins 1 and 2) can be put on one pin rather than 2 as present or if that is just a really bad idea!? Are the live wires going to be always connected between pins 1 and 2 and the on/off switch makes the circuit between live and blue wires, in which case combining the live wires on one pin would presumably be ok? Or not!? Advice welcome please.
Reply to Replacing switch on a domestic heater - DIY question in the Domestic Electrician Forum area at ElectriciansForums.net
Thank you for the suggestion!
I doubt the terminals in those are suitable for 4mm, more likely designed for 1.5mm as they are limited to 16A. You could use the time switch to...
davesparks
