Replacing thermostat wiring question | on ElectriciansForums
Discuss Replacing thermostat wiring question in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Welwyn Garden City
Hi there, im not an experienced electrician but wanted to quickly exchange a thermostat for my electric under floor heating. However the wiring arrangement is different on the new one.
I think I know how they match but would really appreciate it if someone could tell me if I have got this right.
On the attached image, I have drawn the numbers in Red to match the numbers on the original diagram to show what I think maps to where. Would someone Kindly tell me if I have got this right?
Many thanks, really appreciate it![ElectriciansForums.net] Replacing thermostat wiring question
Thanks Murdoch, what I was hoping for was someone just to validate I've got this right or tell me I've got it wrong.
ie, if I put the wires that are currently in location 1-6 into the equivalent slots as I have numbered in red on the new diagram, does this map correctly?
I appreciate that I am novice and if the advice is get a qualified electrician in to do it then fair enough. I wasn't expecting to find a different arrangement when I went to swap them over so just trying to be pragmatic.
Thanks again
Looks Ok to me..
Before you connect, good idea to do a continuity/resistance and insulation resistance test on the probe and the element.
Reply to Replacing thermostat wiring question in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Ignore the post in #3 it is of no help. Hopefully someone may know but it maybe a longshot, have you asked on a more specific appliances forum?
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
