Replacing underfloor thermostat with warmup 4ie thermostat | on ElectriciansForums
Discuss Replacing underfloor thermostat with warmup 4ie thermostat in the UK Electrical Forum area at ElectriciansForums.net
Carlisle
Hi All
This is my first post. I am very novice around home diy electrical work. I can replace sockets and light switches and hold degree in computer science.
I recently purchased a new thermostat for my underfloor heating in the kitchen (warmup 4ie). It is to replace an old thermostat.
I wanted to get some advice before I try to attempt this myself
[ElectriciansForums.net] Replacing underfloor thermostat with warmup 4ie thermostat
The above picture is the old thermostat.
this diagram is the wiring of the warm up 4ie which would be the new thermostat.
my question are:
- looking at the first photo I would be putting the brown wire into connection 2 of the the new diagram?
-And the single blue wire neutral in first photo into connection 3 of the diagram?
-The other two blue wires in first photo neutral would go to connection 4
- the two black wires (live) in the first photo It would go to connection 5?
-the final question is the thin wire in first photo which is the probe sensor would go to connection 7?
I just need confirmation that I am on the correct path. Obviously I will ensure the electrics are of on the main switchboard.
Many thanks
James
Reply to Replacing underfloor thermostat with warmup 4ie thermostat in the UK Electrical Forum area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
The Meross thermostat requires a 240V mains supply, but your original Myson did not, so there is probably no mains supply in the wall there. There...
