W
woodsta
i have been asked to quote on repositioning (lowering 2 metres) a fuse board it has mcbs but nothin is rcd protected should i replace the board with a split load as obviously i will be testing afterwards.
Discuss repositioning a fuseboard in the Australia area at ElectriciansForums.net
if you are extending circuits then it comes under a minor works for each circuit which needs notifying,by extending the circuits you are then resposible for fitting rcd protection.i would just replace the board with a new one and do a full inspection and test on the property.
Reply to repositioning a fuseboard in the Australia area at ElectriciansForums.net
