deamonata
Hi there,
We're currently in the process of getting a new kitchen fitted and I wanted to double check the new wiring that has been installed before I plaster over it.
To clarify the electrics have been organised by the fitter so as fair as I know the electrician is part P certified but I was looking at it and the position of the wire doesn't match my understanding for the safe zones. It's possible I'm worng, infact it's quite likely but I wanted to check.
In the image attached the wire comes across the ceiling as I would expect and then drops down. the point where it comes down is about 150-200mm from the edge of the hob. Is that acceptable or should it be inline with the hob?
I appreciate any advice as If there is an issue I don't want to plaster over it until it's fixed.
