resistance between phases? | on ElectriciansForums
Discuss resistance between phases? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
solo2771
hi just wondered how high the resistance between phases should be on a 3 phase board?
the measurments we got were very low less than 100 ohms, on the board are mainly single phase but there is a 3 phase air con unit and a 3 phase supply to another dis board?
Reply to resistance between phases? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
The total current capacity of the system in amperes is the same as the per-phase rating when referring to a balanced three-phase system. Thus, a...
