Resistance in a Volt meter | on ElectriciansForums
Discuss Resistance in a Volt meter in the USA Electrical Forum area at ElectriciansForums.net
T
timberfinn
Most meters today I understand are multimeters but I am only interested in the volt meter circuitry. The reason I am asking this is because the volt meter seems to only register voltage across a load and not on a plain conductor such as the neutral circuit. In my limited experience and according to my instructor, the volt meter reads zero if you try to get a reading anywhere along the neutral circuit for one of two reasons: 1. "the voltage has been used up at the end of the last load" or
2. the "potential difference (difference in potential?) in the current in the neutral wire between the two leads of the voltmeter is zero". I argued that neither of these can correct because there are always amps in the neutral circuit and you cannot have amps without volts to push the electrons along. I argue that maybe it is possible that the resistance in the neutral circuit is lower (.005 ohms/ft for 12ga. copper wire) than the resistance in the internal circuitry of the volt meter itself since the circuitry wires are obviously going to be smaller in diameter than 12 ga. and thus of higher resistance. The current therefore takes the path of least resistance and by-passes the volt meter. Thus a zero reading in the neutral circuit. I am talking about a single phase 120v residential wiring system, although the principle is the same in any circumstance I would think. So what is the resistance in the internal circuitry of a standard analog voltmeter? Digital voltmeter?
The current doesn't "bypass" the voltmeter although I know what you are trying to say, it just may be too small to measure. Current will always favour the path of least resistance, but that doesn't mean none will flow where the resistance is higher.
Typically a decent analogue meter moving coil may have a resistance of 20kΩ/V DC and 1kΩ/V AC. Digital multimeters can (note can) have higher figures (some are selectable hi z lo z for AC that's a whole topic in itself) but for example 10 or 20MΩ/V DC, 1M or 10MΩ/V AC is typical.
Also you should be talking about impedance not resistance for AC
Across a long length of neutral passing a current you certainly would be able to measure a voltage, but then you'd have to allow for your very long test leads.
We years ago had two types on volt meter, one had an ohms to volt rating the other the valve volt meter in essence generated a voltage and when the voltage measured equals the voltage generated then zero flows between the two circuits.
So on the typical voltmeter we would measure on two scales, if both readings were similar then the volt meter was not causing a volt drop, if they were not you knew the volt meter was causing an error.
Depends
Angry not at you Oracle at the thought of the outcome or what you said in your post
Pete, colleges sell courses first and then look for tutors, I can accept guys coming off the tools to teach after years of experience but that one beggars belief.
The reason why they’re always short of trainers is the kids on funded courses often have floated through school and expect to float through college and life.
The colleges get about ÂŁ3500 for each bum on a seat in the classroom and the poor sod teaching is personally responsible for attendance, achievement, timekeeping etc. Would you like to do that?
No not really no patience for time wasters, or any wasters come to that.
My thoughts are that a meter safe for use at line voltage , will not be sensitive enough for the test you want ,unless extreme loads are present.
( Anything more sensitive needs to be used with great care -as it may not be designed with the correct level of Safety/Failsafe == Not beginner territory )
Yes it does Mate, and that's the worrying part, trouble is all these providers just think of tick sheets and of course bank statements, a sad reflection on training.
QUOTE -
The second statement is equally as preposterous !
A little knowledge is a dangerous thing
And he is teaching his nonsense to others !
Reply to Resistance in a Volt meter in the USA Electrical Forum area at ElectriciansForums.net
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
I fitted a Mem MR30 Pod and MCB, about ÂŁ75 for both.
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
