M
m1ck_b87
Afternoon people
How do you work out the resistance/metre on a ring main is it just the same as working out a radial or does the /4 come into it
do you mean end to end ( r1, r2, rN ) or R1+R2?
Afternoon people
Well, consider what you are measuring. Two legs of a radial circuit where the legs are in parallel.
So what value would you expect to see at the physical mid point of the ring (the furthest physical point from the origin) ?
resistance/metre
Thread Tags
Tags Tags
None
m1ck_b87,
ackbarthestar,
