Resistance of 1.5mm flex per meter | on ElectriciansForums
Discuss Resistance of 1.5mm flex per meter in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Cardiff, but work SW
Hi, just carrying out some testing and a few of the figures I'm getting seem way out. Just wondering of anyone knows the resistance per meter of 1.5mm. 3core flex. I'm stuck in work with no regs book and can't find bog all online. Cheers guys!
A tip I always use...try and remember 1.00mm = 18.1 ohms per 1000 metres (or 18.1 milliohms/metre) that is the only resistance you need to remember eg in your case 18.1/1.5 = 12.06 (12.1)/1000 = 0.0121 ohms per metre. In this case 0.012 * 2 (R1 + R2) = 0.024/metre. It will go out slightly as against table E.1 for the larger size cables but is close enough for quick calculations.
Reply to Resistance of 1.5mm flex per meter in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yeah I did think this. Once again. Thanks for all your help.👍🏻
Hi I've nearly completed the 2357 NVQ. I'm just a bit stuck with Permits to work, Planned program of work and method statements. I work in the...
