Resistor value ? | on ElectriciansForums
Discuss Resistor value ? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
here we go, its been a while since i was at college. total resistance= voltage/current (R=V/I) 20/0.25= 80.
Resistance in series = R= r1+r2, so 80-5= 75. so you have 75 ohms to account for. resistance in paralell = 1/r= 1/r1 =1/r2 . so 1/75 -1/10 = 11.53.
Hope i got it right, and that it helps.
Some of the blokes on here are lecturer's so im sure they will be along soon to mark (and fail) me!
:D
Upvote 0
work out voltage across 10 ohm resistor
unknown resistor will have same voltage
work out voltage across 5 ohm resistor (simple subtraction)
calculate current thru it
work out current thru unknown resistor
work out resiistance of unknown resistor.
Upvote 0
im liking bumping into your posts again mate:)nice one;)
Upvote 0
Go on then.
P.S. Empty your PM box :p
Upvote 0
work out voltage across 10 ohm resistor 0.25 x 10 = 2.5V
unknown resistor will have same voltage 2.5V
work out voltage across 5 ohm resistor (simple subtraction) 17.5V
calculate current thru it 17.5 / 5 = 3.5A
work out current thru unknown resistor 3.5 - 0.25 = 3.25
work out resiistance of unknown resistor. 2.5 / 3.25 = 0.77Ω
My Green
I think :confused:
Upvote 0
Reply to Resistor value ? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Commonly known as double knock, some pirs have a latch on time delay for a few seconds, giving time for the 2nd one to activate .
Thank you, I'll give it a try 😊
Electrical Courses
