retrofit dual rcd boards | on ElectriciansForums
Discuss retrofit dual rcd boards in the Australia area at ElectriciansForums.net
C
cuffy68
when fitting a dual rcd board 17th edition , what are you supposed to do with an immersion heater circuit as many cause the rcd to trip anyway ?
I don't like using these boards, but if cost is an issue thats what you use, normaly there is space after the main switch to install a couple of RCBO's i would put the immersion on one of these that way if there's a problem it only trips that rcbo
Regards
AJ
ok thanks, so its another $40.00 + vat for a shrinking market, lets just price ourselves on the dole, thanks agan nic , nappit and all the other main people for making it near immopssible to make a living
No reason for an immersion to tripp an rcd anymore than a kettle, toaster, iron, or the likes. Rcd is just doing its job should a fault occur.
Only time I found issues was when protecting a bank of stand alone computers, to many on a given circuit can cause nuisance tripping, but it was asked for in the spec.The answer was dedicated supplies to each with 20A rcbo's. Expensive but gave the client what he wanted.
Reply to retrofit dual rcd boards in the Australia area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
It can also mean lasts or continues for two years.
