reverse a single phase AC motor | on ElectriciansForums
Discuss reverse a single phase AC motor in the Electrician Talk | All Countries area at ElectriciansForums.net
J
jmtisme
how would I work out the size of capacitor I need to reverse a single phase motor.
Not sure of the size etc as not been out to see it yet all I know is the customer has a fan they want to reverse its in a machine so don't think a fan controller would suit.
if you can get at the terminals of the windings, reverse the start winding.
You can reverse either the start winding wires or the run winding wires, either option will give you reverse running, just don't reverse both windings.
Hi
some motors are marked z1 & z2 these are the start windings and just need to swap them over, if no markings measure the resistance on the 2 sets of windings and the higher of the two will be the start.
Hope this helps
regards
gary
If you can't get at the windings as they are sometimes inside the motor, you could always take the impellor off and refit it the opposite way around.
Reply to reverse a single phase AC motor in the Electrician Talk | All Countries area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
Have you got the lid of the connection box on the motor? Often there's a wiring diagram inside the lid. What is the make and model number of the...
