Reverse camera interference | on ElectriciansForums
Discuss Reverse camera interference in the Auto Electrician Forum area at ElectriciansForums.net
BMGBMG
Dartford
Hi all, I'm wondering if anyone can help with an install problem on my car. I fitted a reverse cam to a 2002 Range Rover along with a android head unit. I spliced in to the loom at the rear and took a feed from the reverse lights and all worked well, that is until I switch the cars ( xenon ) headlights on and this makes the screen jump around.
Any ideas on what I could do to fix this ?
might benefit from a relay... coil energised by reverse lights. contacts to power camera. i have a somewhat similar problem. evry time i turn on LED headlights, i get RF that swamps the radio on weak stations. (my reversing camera is powered from the rear screen demister (which is kaput anyway)so it's on when i want it, not just when i'm going backwards).
Reply to Reverse camera interference in the Auto Electrician Forum area at ElectriciansForums.net
Ok, after trying two different flashers supposedly for Led bulbs, I got one that also has a ground wire, and it worked. I now have operating turn...
I've discussed this with the OP directly as we are friends, but for anyone searching in the future, the service manual suggests that this...
