Hi folks been asked by a customer is possible to wire his industrial shredder so that it could reverse as well as go forward? Due to it becoming jammed frequently, it a three phase and neutral supply and help much appreciated.
Discuss Reverse shredder in the Electrician Talk | All Countries area at ElectriciansForums.net
Hi markssparky,
I assume there is a contactor for the motor in it. You'll need a second contactor, wired with any two of the three phase swopped over, electrically interlocked with the original contactor. Add a selector switch
which selects one of the two contactors. If the circuit is star/delta then it is a bit more complicated as you need two star delta starters, one for forward, one for reverse.
Have you got a circuit diagram which you could post?
Reply to Reverse shredder in the Electrician Talk | All Countries area at ElectriciansForums.net
