rewirable fuse type | on ElectriciansForums
Discuss rewirable fuse type in the Australia area at ElectriciansForums.net
M
Monitor
Hope someone can help. How can i tell what type of 3036 fuse i am looking at and what is the breaking capacity. This is to put on a periodic form.
If you follow this link and click on the 2008 wiring matters 4th sub heading and download the info
I am sure you will find what you require
Wiring Matters - 2008 issues - IET Electrical
Thanks very helpful, but how can i tell by looking if its a s1a s2a or s3a, are there any markings as i cant see any.
Typically BS3036 re-wireable fuses found in domestic consumer units are S2A category of duty. On Wylex and some other BS3036 boards there is often a label (if the glue hasn't dried out and the label dropped off) or moulded in the plastic on the inside of the fuse carriers outer cover which provides data on the category of duty, SWG and nominal current rating of fuse wire.
Reply to rewirable fuse type in the Australia area at ElectriciansForums.net
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other...
