Hi chaps,
Got a rewire to do for a friend, but having to do it in various stages due to the house being occupied and VERY full of "belongings"!
Was planning on doing the job over several weekends. The priority is both lighting circuits. I had to disconnect them a while back when I went to replace a light fitting and found everything was wired in rubber singles which fell to bits in my hands.
I was planning on running all the new circuits, testing, connecting to the existing DB (15th Edition I think) and when the rewire is done, fit a new DB.
However, this would mean I was installing new circuits, which in the meantime will not be RCD protected. Obviously it would be very handy to be able to use the new lighting circuit in the meantime, but I'm aware it wouldn't be compliant.
Ideally I'd install the new CU straight away and connect the new circuits to that when they're completed and tested, but it's not really an option as it's got to be installed in a small cupboard.
What does everyone think?
