In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s from the 80s when the board was first split, I believe) - can someone tell me if when asking for a quote to rewire, would the storage heaters and their separate consumer unit be classed as a separate rewire?
I know that sounds stupid - but my neighbour had asked me to take a look at an issue he was having and I've discovered that the property was rewired in 2016 with a new consumer unit fitted for the ring main, lights and hot water (immersion) etc., but that the consumer unit for the storage heaters wasn’t replaced and that the storage heater circuits themselves are still the black and red wiring meaning they haven't been rewired either.
Is it normal to do one and not the other? He’s an OAP and it was funded through a scheme and I’m just wondering if the contractor has taken liberties or would a Spark treat each CU as a separate rewire.
Thing is – it apparently cost 3 grand – but it’s only a two bed flat so I’m struggling to see where the money went as another neighbour had their 3 bed house done for £1800 in 2019. (I’m in Scotland so things are a wee bit cheaper – or at least they were…)
So besides the probable obvious rip-off here – if you were called to quote a rewire on this property with two CU, would you treat them as two rewires or one job?
