Rewire required. | on ElectriciansForums
Guest viewing is limited
Discuss Rewire required. in the The Welcome Forum area at ElectriciansForums.net
Montana
Most effective way to upgrade housing wire. Needs everything. Built 1885. Don’t want to walk into it, totally blind.
Reply to Rewire required. in the The Welcome Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
Recommended Sponsor News
Hi everyone,
