the house i am due to rewire has floorboards on the ground floor, can i rewire the sockets from underneath the same as you would the first floor ? are we permitted to drill out as normal ? tia
Discuss rewire in the UK Electrical Forum area at ElectriciansForums.net
Why?Sure you have to come down the walls on the ground floor.
??? whynot up from below, as the per upstairs socketsSure you have to come down the walls on the ground floor.
Is there not a space underneath the timber joists? you wouldn't need to drill any joists.the house i am due to rewire has floorboards on the ground floor, can i rewire the sockets from underneath the same as you would the first floor ? are we permitted to drill out as normal ? tia
Is it an old property? in my younger days we used to be able to cut a trap in the ground floor timber boards and sen the Apprentice down the trap, and all we did was to push cables down at the positions of the sockets and get him to run the cables around the downstairs ring, mind you in todays Nanny state you might get in trouble for exploiting the young.Dunno yet
Reply to rewire in the UK Electrical Forum area at ElectriciansForums.net
