G
Gerry24
I've been asked to replace a standard overhead ceiling lamp with an old chandelier. It weighs about 8kg so think I will be OK hanging it from a noggin attached to joists. It only has 2 lamp holders (brass bayonet with earth screw) but the wiring looks pretty tired so I said I would only fit it if I rewired it. But, I haven't ever rewired one before. So here's what I'm thinking. Replace existing brass lampholders with new ones with earth screw. Rewire in 0.75mm 3 core with gold pvc sleeving. Attach cpc to earth screw on lampholder and line and neutral to pin terminals as normal. Run both cables up to junction box in ceiling. Fit two 20W CFLs.
Any views?
Any views?
