jamesuk12345
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just one pendent light. this was the original setup attached.
I have rewired the new standard light switch, the passthrough is working as the other switches work up stairs, but the single light pendent is not workig now (no power) . I tested the same switch with a single spotlight and it works but ver dim. Im not sure where the black wire goes in the switch?
To the pendent there is a red, black and earth wire.
Thanks in advance
Thanks in advance
