Rewiring | on ElectriciansForums
Discuss Rewiring in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
See when rewiring, if there’s an old conduit system in the property. Do you use that to wire and if so do you use the old box that there or do you use a new box?
Is is an entire conduit system or is it just the drops to sockets and switches?
Not seen it often in houses {assuming this is domestic}, have seen it in blocks of apartments quite a bit, it's a complete ball ache as it's unlikely a rewire won't be having extra points added.
Reply to Rewiring in the UK Electrical Forum area at ElectriciansForums.net
Pretty common for lights and sockets to get a Re-wire and the Eco7 circuits usually storage heaters /water heater to remain left as was. As for...
Its down to the budget and your experience level - If they cannot pay you cannot work, If you dont know whats safest you shouldn't work - If you...
