RF interference from wind turbine?? | on ElectriciansForums
Discuss RF interference from wind turbine?? in the UK Electrical Forum area at ElectriciansForums.net
herefordshire
Hello all,
I have a customer who wants to install an internet bridge. The equipment is quite cheap if you use the 5Ghz frequency, but to save costs I would like to put the receiver on an existing wind turbine mast, which has a 2.5kW turbine on it.
My question is, would the turbine motor be likely to cause RF interference with the receiver? It would be mounted about 3 mtrs below the motor.
The salesperson for the receiver says no, I'm interested in other opinions.
Thanks for any help...
Ben
Hello all,
Ben
Can't help I'm afraid
Other thought , do they cope with a bit of microphony .
Rubber mount ?
( Mechanical vibration .. not tried beating one with a rubber stick !)
Remember some transmited mechanical noise on a local towerblock .(may have just been reflected sound,from blades - poor windows )
( Moving blades getting in reflected signal paths may get interesting )
We had an intermittent fault on a wind farm microwave link. Every so often there would be a very short but repetitive transmission break that was messing with the backhaul.
When the wind changed direction the head would rotate and the blades were blocking the link as they spun, the link installer got some grief for that one...
Luckily the prevailing wind will put the blades on the other side of the mast to the receiver for the vast majority of the time, but I want to avoid the problem entirely because the link will be for general internet use not simply data logging info. I am making a bridge from someone with a Fibre connection to someone else on a very poor broadband connection miles from the exchange.
Reply to RF interference from wind turbine?? in the UK Electrical Forum area at ElectriciansForums.net
