Small job adding a few sockets, while doing some preliminary checks I found this reading on the socket circuit!
After hours of fault finding -
Searching for any possible connected loads -
Questioning if the SFS's were DP then disconnecting the load N (found SP SPS's online) -
Breaking circuit in halves each time left me between 3 sockets....
The one in the middle was a radial!
Lifting floorboards searching for a JB, the spur from the middle socket disappeared into a bedroom towards under a large wardrobe!
(FFS, quick smoke)
Sticking my head and torch into the floor voids tracing the leg from the previous socket I noticed the cables appeared to go down to GF.
Found a socket behind a radiator!
Above that was a picture..., tested from nearby socket to picture hook SAME READING!
Removed picture hook and reading dramatically improved
It was already very late and I still had to put back all I'd taken apart so will chop the wall section tomorrow to repair.
Client was very happy the problem had been found but I couldn't explain why It hadn't caused the RCD to trip??
BTW - RCD test have been carried out and all ok.
(FFS, quick smoke)
