Rgb lighting. | on ElectriciansForums
Discuss Rgb lighting. in the UK Electrical Forum area at ElectriciansForums.net
LONDON (barnet)
Good evening all, I'm looking for some advice on rgb setups.
If I wanted several rgb floods to work simultaneously from the same remote would they be wired in the same way as led strips threw an amplifier if so where could I get a rgb wired fitting.
Or would there be some sort of signal which would go from a main point to each individual flood.
Reply to Rgb lighting. in the UK Electrical Forum area at ElectriciansForums.net
Hi Did you fix your lights? Would love to see a photo of your bike!
Unfortunately, it looks like they are UK only.
