RGB tape & controllers | on ElectriciansForums
Discuss RGB tape & controllers in the Electrical Tools and Products area at ElectriciansForums.net
sam400
sussex
Hi can anyone recommend me some LED tape and controllers,
I need to fit tape in 4 different areas and control them all wirelessly with the one remote if possible?
Haven't got involved in much of this so if someone could point me in the direction of the right product that would be great.
cheers
sam
You can buy it at a good price off Amazon
Basically you have 2 different sizes the smaller one 3528 and the larger one which is 5050, The 505o will be brighter etc.
The actual connections are pretty straight forward.
You have a PSU, which connects to a controller which in turn connects to your light strip.
The controllers are operated by a little remote to turn them on/off select colours/patterns etc.
Afraid I have never tried to control more than 1 at a time so I dont know how well that would work but you can Joint them into 3 sections using jumper leads if that is possible I did my kitchen units in this way :)
Thanks for your reply tiny,
I really need to control the 4 units with one remote and there is no way to interconnect them unfortunately.
Buy all the same one control will work for all, go for the more expensive ones not for Amazon but from a uk maker will try to post a link when I get home.
Sent from my iPhone using Tapatalk
Reply to RGB tape & controllers in the Electrical Tools and Products area at ElectriciansForums.net
more the merroir, if not good for me - good for others on here :-)
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
