RHI MCS Metering Guidance | on ElectriciansForums
Discuss RHI MCS Metering Guidance in the Green Lounge (Access Only) area at ElectriciansForums.net
Lincolnshire
Hi Folks
If the heat pump is going to have payments related to the EPC would I still need to install the valves for a heat meter
thanks
yes.
The only technology that doesn't need that is solar water heating*
*thanks to me pointing out how impossible to achieve this would be in most airing cupboards etc in a conversation with the head of the SWH technical working group. Ironic that the only impact I've actually had on MCS is via a working group I don't sit on and have never attended a meeting for.
Systems have to be 'meter ready' even when you don't install meters.
Reply to RHI MCS Metering Guidance in the Green Lounge (Access Only) area at ElectriciansForums.net
