L
Lofty
Hi All,
Anyone else used one of these yet ?. Richmond have produced a dimmer (Grid 500) to use on CFL and LV lighting including LED. It has a small adjustable trimmer on the side so you can set it up with the load. We had an issue with Halers dimmables ( 8 off) that would flicker at low dimmer settings . Changed the dimmer twice to no avail until we were put onto this one.
Note:- Min loading for LV on this dimmer is 40W.
Also as an aside to this Halers have told me also that from about last October they have had to re-design the driver circuit as they had a few problems. They swapped our units over F.O.C. with no bother.
Cheers,
Lofty.
Cheers,
Lofty.
