H
harrison2987
Above is a picture of 2 16mm SWA cables terminated into a termination block. In my opinion this is the correct way to dress in the SWA and terminate it into the incoming side of the termination block, not putting it into the same termination as the outgoiong cables.
Is there a reg that says you have to terminate like this? Or is it just good practice to do so??
Below is how another spark has terminated the 2 SWA cables. He has gone straight into the top of the termination block, into the same terminations as the outgoing cables.
Just to be clear there are no fuses on this termination block, it is simply a through termination, i just want to know which way is corrct or better practice and if there are any regs to say which is the better way to terminate.
Thanks in advance for your opinions and help!!!!
