M
mrmatt
Hi
I have installed a ring with 7 sockets on it
when insulation resistance testing these are the results i get
L-N >500Mohms
L-E >500Mohms
N-E 6.8Mohms
as this is a new circuit i am not willing to accept the N-E reading of 6.8Mohms as i consider it well low although it does pass the regs.
Thing is if i split the ring at the first socket and test both ends of the cable at the CU i get >500Mohms and if i test at both ends of the disconnected socket same reading >500M ohms. I thought this may mean a faulty socket so i put the cables into a connector block at the socket and i get the same low reading when i test at the board.
Has anyone got any suggestions?
Matt
L-N >500Mohms
L-E >500Mohms
N-E 6.8Mohms
Matt
