Ring continuity voltage at dead test | on ElectriciansForums
Discuss Ring continuity voltage at dead test in the UK Electrical Forum area at ElectriciansForums.net
N
newtrade
Hi guys
doing a ring continuity test . R1,Rn,R2 values all okay. Done figure of 8. Tested at each point and not allowing continuity test due to 8 volts. Stuck on what this is? Any ideas ?
Do a walk around and visually check that everything is off, I have been into houses before and someone has Henley blocked before the meter to another CU.
Other option is they borrowed a supply from next door.
Saying that I was at a house last week, CU change - up in the attic was 2 rings. One for the house I was working on and 1 for next door.
It turned out the attic wall as 2ft over next door instead of directly over the separating wall
Reply to Ring continuity voltage at dead test in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
