ring continuity | on ElectriciansForums
Discuss ring continuity in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
steve.t.
doing a ring main continuity that is all on one ring differ, while cross connecting the L and N it was 0.15 in living room, 0.30 upstairs and 0.45 in kitchen, have checked for a ring within a ring and made sure i cross connected correctly. checked the Zs from one of the sockets and that was ok. Any help greatly appreciated
reverse your interconnection's.
If still the same, then the sockets have been spurred off. You might need to take a few off, and have a look, always a good idea to take a couple off, will give a very good indication of the install.
Reply to ring continuity in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
