Ring continuity | on ElectriciansForums
Discuss Ring continuity in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys under what circumstance would a ring circuit continuity test NOT be required during an inspection and test ?
or if the I&T is for a letting agent at ÂŁ30 per visit. drive by EICR.
Surely you would test RFC continuity under a EICR? Or are you suggesting there may be particular circumstances under which a LIM could be applied instead of doing these particular tests? If so, then how about a couple of examples?
During periodic inspection and testing where there are records of ring final circuit continuity tests and where there is no evidence of any alterations to the ring final circuit then it is not necessary.
but for how long it takes, i would check it. who's to know if the client hasn't added a socket outlet and broken the ring.
Safety circuit in an hospital could be one
IT circuit in a Tier 4 Data Centre could be another.
what circumstance??? Hmmmmmm, let me think??? If it is a RADIAL CIRCUIT??? :tongue3::tongue3::tongue3: sorry could not resist, allways test as you not know if there has been any previous work been done, just be safe.
Reply to Ring continuity in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
