Ring Doorbell Transformer Location | on ElectriciansForums
Discuss Ring Doorbell Transformer Location in the DIY Electrical Advice area at ElectriciansForums.net
philcox
Kent
Is it acceptable to mount a ring doorbell transformer in a double back box with a flush cover / fused switch?
I can’t get the wires back to the CU and don’t want a large box sticking out the wall.
I can’t see how you would mount it, they are to be mounted on a din rail if I remember correctly.
it should not be just floating around in a box.
You can get DIN rail boxes for mounting flush in a plasterboard wall, e.g. (scroll down):
Obviously a bit larger than a double back box.
Reply to Ring Doorbell Transformer Location in the DIY Electrical Advice area at ElectriciansForums.net
Hi, How did you install your doorbell in the end?
How about one of these ? No supply needed and has the benefit of having an array of different knocks for all types of moods.
