Ring Doorbell Wiring Query | on ElectriciansForums
Discuss Ring Doorbell Wiring Query in the UK Electrical Forum area at ElectriciansForums.net
lwj983
UK
DIYโ€™er here, so be kind.
I am after some advice on fitting a wired doorbell in the UK. I plan on removing the current chime and replacing it with a 24v Ring transformer only in a box.
Planned on simply adding the power and adding the 2 cables to the Ring bell....Job done!
However, looking the current doorbell it has been fitted with a 6 core wire, the type you use for burglar alarm sensors. They have used single wires on the 8v fitting and left the other 4 just spare.
My question is, would the current 6 core wire handle the 24v either on a single wire or by splicing the 3 wires together to increase its load ability? Anyone had a similar issue?
Thanks,
  • [ElectriciansForums.net] Ring Doorbell Wiring Query
Reply to Ring Doorbell Wiring Query in the UK Electrical Forum area at ElectriciansForums.net
Hi, How did you install your doorbell in the end?
  • How do I talk to a real person at British?~๐”ธ๐•Š๐•‚#โ„š๐•ฆ๐”ผ๐•ค๐•ฅ๐•š๐• ๐•Ÿ
    How do I talk to a real person at British? ๐•๐• ๐•ฆ ๐•”๐•’๐•Ÿ ๐•”๐• ๐•Ÿ๐•ฅ๐•’๐•”๐•ฅ ๐”น๐•ฃ๐•š๐•ฅ๐•š๐•ค๐•™ ๐”ธ๐•š๐•ฃ๐•จ๐•’๐•ช๐•ค ๐•”๐•ฆ ๐•ค๐•ฅ๐• ๐•ž๐•–๐•ฃ ๐•ค๐•–๐•ฃ๐•ง๐•š๐•”๐•– ๐•“๐•ช...
  • Can you get a refund through Expedia?
    ๐”ผ๐•ฉ๐•ก๐•–๐••๐•š๐•’ ๐• ๐•—๐•—๐•–๐•ฃ๐•ค ๐•’ ๐•˜๐•–๐•Ÿ๐•–๐•ฃ๐•’๐• ๐Ÿค๐Ÿฆ-๐•™๐• ๐•ฆ๐•ฃ ๐•”๐•’๐•Ÿ๐•”๐•–๐•๐•๐•’๐•ฅ๐•š๐• ๐•Ÿ ๐•ก๐• ๐•๐•š๐•”๐•ช. ๐•‹๐•™๐•š๐•ค ๐•ž๐•–๐•’๐•Ÿ๐•ค ๐•ช๐• ๐•ฆ ๐•”๐•’๐•Ÿ ๐•”๐•’๐•Ÿ๐•”๐•–๐• ๐•ž๐• ๐•ค๐•ฅ...
  • {๐•๐•–๐•ฅ๐•“๐•๐•ฆ๐•–} Do you have 24 hours to cancel with JetBlue?+44-(804)-853-9001
    Do you have 24 hours to cancel with JetBlue? ๐•๐•–๐•ค,๐•๐•–๐•ฅ๐•“๐•๐•ฆ๐•– ๐• ๐•—๐•—๐•–๐•ฃ๐•ค ๐•’ ๐•˜๐•–๐•Ÿ๐•–๐•ฃ๐•’๐• ๐Ÿ๐Ÿ’ ๐ก๐จ๐ฎ๐ซ๐ฌ ๐œ๐š๐ง๐œ๐ž๐ฅ๐ฅ๐š๐ญ๐ข๐จ๐ง...
