ring final 8 | on ElectriciansForums
Discuss ring final 8 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
s.keech
When testing ring final how do i know incoming and outgoing legs when cross connecting L & N. Will the readings at each socket be considerably different when they should be roughly the same. R1 +Rn/4 at each socket. Cheers
cross connect L1 to E2. then R1+R2 at each socket should be the same, unless a socket is on a spur. roughly = (r1+r2)/4.
Reply to ring final 8 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
