A
Abot
Everytime i use the brand new iron and ironing machine after a few minutes, the breaker trips off. Its annoying to go to electric panel board turn on everytime. The iron and ironing board machine has 2200 wattts. The ring final circuit breaker got 32amp which is enough to protect the sockets. Well, in that circuit is plug with washing machine, dryer, printer, oven and cooker. But even though only the iron and ironing board is in use, still the breaker strips off.I don't know why it keeps tripping off. Please anyone have ideas :-( :-)
@Kingeri: Actually, other appliances are working properly, so wiring and circuit breaker are good. Yeah might the iron and ironing board is the culprit. Cheers
Are you sure it's the MCB (breaker) and not a RCD (will have a button with T or Test written on it)?
If you have more than 1 socket circuit (or socket on cooker point) try it on one of those first but your best options are
1) Get an electrician in
2) Take product back to shop
ring final circuit breaker trips off
Abot,
supersparky89,
