Ring Final Circuit - spurs only | Page 5 | on ElectriciansForums
Discuss Ring Final Circuit - spurs only in the UK Electrical Forum area at ElectriciansForums.net
London
I read that it is against the regs that a ring final circuit cannot be just a ring with with spurs off it. In short, a ring must have sockets on it which double up as junctions. I find that hard to believe.
You inferred that a 750W fridge was the cause of thermal damage to a socket, whereas the response pointed out that other factors were much more likely to have caused the damage - factors which aren't removed by hardwiring an appliance.
Hard wiring a permanently connected appliance, rather than permantly plugged into a portable appliance outlet, make matters safer.
Perhaps you could expand upon this as I fail to understand how a 750W fridge is 'made safer' by hardwirng through an outlet plate, than connected via a BS1363 plug/socket arrangement.
It is obviously far safer for a homeowner who has bought a new fridge to cut off a factory fitted plug and connect the flex into an outlet plate, having been to a wholesaler and purchased 3 individual ferrules, than it is for them to plug it in to a socket!
Those rules they brought in about all new domestic appliances being supplied with a plug fitted to them were obviously pointless, they days of people having to fit their onw plugs to everything we're far safer.
What is a 'portable appliance outlet'? You can't just change the name or definition of a socket outlet to suit your argument!
If hardwiring of domestic appliances made things safer then the rules wouldn't have been changed to require all appliances suitable for connection by a 13A plug to be supplied with one fitted!
I used to believe this too. I don't know if it was included in the 15th or 16th edition, but there's no mention of it in BS7671:2018+Amd2:2022 (at least as far as I can see).
Drew a blank in BBB, but H2.4 of new OSG is clear on this point:
"....the number of non-fused spurs should not exceed the total number of socket outlets and items of stationary equipment connected directly in the circuit".
As such the number of sockets isn't the issue, but the number of points connected directly to the ring.
Reply to Ring Final Circuit - spurs only in the UK Electrical Forum area at ElectriciansForums.net
Yep! Edit button was disabled by the time I seen it. Hopefully the 15m/15m clarified what I intended 😀
2 3
Very technical :D
