Ring Final Circuit - spurs only | Page 6 | on ElectriciansForums
Discuss Ring Final Circuit - spurs only in the UK Electrical Forum area at ElectriciansForums.net
London
I read that it is against the regs that a ring final circuit cannot be just a ring with with spurs off it. In short, a ring must have sockets on it which double up as junctions. I find that hard to believe.
The back box is a dual backbox slightly wider than a standard double back box allowing 2 single face plates to be fitted, be they single socket outlet, flex outlet or FCU.
Or you could use one of these
[ElectriciansForums.net] Ring Final Circuit - spurs only
And have a double socket and a spur
Just thinking about every point being a spur off the rfc, and no actual points as part of the rfc…..
What if you want to add an additional socket or point next to an existing?
You would have to go to the joint box rather than a local socket.
Reply to Ring Final Circuit - spurs only in the UK Electrical Forum area at ElectriciansForums.net
Yep! Edit button was disabled by the time I seen it. Hopefully the 15m/15m clarified what I intended 😀
2 3
Very technical :D
