Recently I had a kitchen installed obviously the kitchen fitter electrician modified the wiring; an RCD was added on the kitchen ring main (so I was told).
The RCD (CEB RC63BR) is there and is working correctly but is not just protecting the kitchen but the whole house, everything works fine no complaints with it
My concern arises since I want to install an electric fire (1.8-2 Kw) in the living room in place of the actual gas fire, there is a plug on the ring main so easy to connect.
In the kitchen I have a: tumble dryer, a canopy fan, dishwasher, washing machine, microwave, fridge freezer plus the usual kettle toaster and mixer.
Hob and oven have their own supply
In the living room I have a 42 Plasma television, and a PC desktop another 2 little television are upstairs the wife occasionally uses the iron and vacuum cleaner.
I am worried that the use of the electric fire will overload the wiring.
I have an old fashion CU but not with wire fuse, there in the CU is a spare place for another fuse and circuit.
The CU is fitted on an under stairs cupboard adjacent to the kitchen should be no problem to branch the kitchen main ring on a new circuit or at least connect a radial circuit to the tumble dryer.
I will contemplate an eventual replacement of the CU.
I am a retired electronic Tech, I do understand about electrics but this job maybe has to be done by a qualified electrician.
Is there somebody that can help? Will be possible to have an estimate? I am living in RM post code area
