J
jimmylaud
hi had a friend on the phone tonight wondering about his down stairs ring blowing the fuse he says he had a old meggar lying about and tested insulation with everything unplugged and the cables dissconected from the board and he had a dead short between live neutral and earth what do you think is the best way to repair dissconect at all sockets split the ring and test as you go to find the faulty leg or what ever is causing the fault? thanks alot in advance
