Ring Main Fault | on ElectriciansForums
Discuss Ring Main Fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
Jimmyb
hi all, Got called to a job tonight, ring main blowing fuses, did the usual and disconnected all equipment and did insulation test and got a result 0.01 Meg ohms between between live to earth, and live to neutral, so then did a continuity but got open circuits on all test, i joined live&neutral together and insulation tested it again to check there was nothing i missed to disconnect even thought I'm 100% sure there was nothing, i have to back tomorrow to try and sort it out but could any give me any pointer as i could understand why the open circuit.
thanks.
is it blowing a fuse mcb or tripping the RCD , did you do a ring continuity , and its open circuit or a continuity of the conductors to earth ie live to earth continuity , do a live to earth continuity see if you get a reading if you do test at each socket and see where you get the lowest reading and then check that socket , if the fault is located re do the IR but do it a 250 volts first
it the old push in fuses, i did a continuity of conductors to earth and it was open circuit on all legs joined (Live & Live joined, Netural & Netural joined to earth) but 0.01 Meg ohm on insuation
Well maybe it falls between 2,000 & 10,000 ohms?
I doubt it though.
0.01 Megohms is, as you say, 10,000 Ohms. If reading to two decimal places then anything above 0.005 Megohms would read 0.01 Megohms and anything below presumably 0.00 Megohms. If that assumption is correct then it is reading at least 5,000 Ohms between line and cpc or whatever was being measured..
Well done.
Reminds me of a nuisance client I had last year where I carried out a periodic and had the same thing. He was an electronics engineer and refused to believe you could have an open circuit and a below 1 megaohm at the same time. I ended going back to redo the tests with him watching, turned out to be water penetration in an outside light (it was snow at the time). He withdrew his complaint.
thanks
snow can cause so many troubles
if snow can close half the schools, bring the country almost to a grinding halt, who are we to compain about an occassional trip caused by snow in the electrics
Reply to Ring Main Fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
