I
IRB
When I turn a load on on the ring main it trips the rcd, is this due to there being a fault between neutral and cpc?
Discuss Ring Main Fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Have you got the neutrals in the right bar in the CU?
trips out on all socketsdoes the RCD trip on all socket outlets, or just 1 of them? could be a N/E reversal.
Reply to Ring Main Fault in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
