Ring main MCB tripping, nothing plugged in. | on ElectriciansForums
Discuss Ring main MCB tripping, nothing plugged in. in the UK Electrical Forum area at ElectriciansForums.net
Southampton
Hello everyone,
Bit of a confusing one. I have a ring main on a 32A mcb. The MCB keeps tripping, sometimes the circuit will stay on for around half an hour then suddenly trip. This is still tripping with nothing plugged in. I have checked all sockets and made sure all connections are tight inside and sockets or switched spurs. Im not sure how the ring was wired as the cables inside the DB are the old colours yet all the cables i have checked that i can gain access too are the new colours so i believe there is more into it. I was just wondering if anyone has had any experience of this before and if so what i should be looking for as im stumped? Is it a break in the cable? but why would it stay live for 30 mins then suddenly trip?
need to test the circuit. esp.IR tests and a leakage clamp meter would come in handy. it could even be a faulty RCD or leakage on other circuits adding to any leakage on the ring circuit. doytou have access to test gear? if not, all you can try is to switch all other breakers off except the ring breaker, then see if it still trips. failing which call in an electrician.
Hello everyone,
If you are 100% sure nothing is plugged in or connected via a spur unit, then I would guess you need to look at what ever doesn't work when the CB is Off.
Is the OCPD an RCBO, or just a plain CB.
Best advice get an electrician in to carry out some testing IR continuity etc.
Hello everyone,
Any recent work been done on the electrics?
The MCB is on a spit board. The main RCD does not trip, only the MCB. ive taken all the fuses out of the FCU as well.
definitely need some electrical testing done soonest, any water leaks recently, outside lighting tagged on the the Ring Final Circuit (RFC) ?
there is an outside light on the circuit but when i switch the circuit on the light works no problem but after 30mins the circuit will trip. even when i take the fuse out of the FCU controlling the outside light it will trip with nothing visibly on the circuit.
Reply to Ring main MCB tripping, nothing plugged in. in the UK Electrical Forum area at ElectriciansForums.net
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
