Ring main not 32amp | on ElectriciansForums
Discuss Ring main not 32amp in the Australia area at ElectriciansForums.net
J
Jimmyb
I’ve been asked by a family member who has just had some new wiring in his house if I could look over the job as they didn’t get why they had to have 2 rcd's now, I told them about the new regs but for their piece of mind I said ill pop over some time and have a look, everything look spot on apart from one thing the old downstairs ring being on a 20amp mcb when I look at test sheets it was tested as ring and all results was good so I decided to check it myself, all results the same as on sheet, so I thought ill ring him and ask,
the reply I got was the cable ref method was 102 due to the wiring being dropped down from upper floor and into the wall. I asked why not use 4mm then but he said it hard getting 2 x 4mm cables into the sockets
so my question is are 2.5mm rings with ref method 102 ok on 20mcb, I’ve only been in the trade for 2 years so wondered what you guys thought
Jimmy
I don't think that you can berate the electrician but whilst the was right to put a 20A mcb on the circuit due to reg 523.7, he should have avoided that route in the first place (unless it is the only route down). As you said perhaps 4mm would have been a better choice.
The problem being, unless clearly marked, then in years to come who's to say that someone won't see a ring & decide change the breaker for a 32A.
Getting 2 4mm cables into a socket is not a difficult task...just undo the screw a little more
Just put 4mm in for a couple of ring mains due to the length of run and had no problems terminating
I'd say its ok to put on 32A
What is the maximum current carrying capacity of a ring circuit ref method 102 is it 42A ????
Yep, agree with you notsosmart. Current carrying capacity for 2.5mm using ref method 102 is 21A, so 20A mcb ok.
This should be clearly stated on the schedule of circuits and test results. Anyone doing later work on the installation should check any documentation and certification before starting :D.
but the current carrying capacity of 2.5 installed method C is 27A therefore we shouldn't be protecting by 32A !
Reply to Ring main not 32amp in the Australia area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
