ring main | on ElectriciansForums
Discuss ring main in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
foghorn
hi guys
yet another head scratcher i am doing a board change and have 3 cables for a ring main LIVE LIVE 0.45 N+N 0.45 CPC 0.68
other cable also reads on the end to end 0.12 0.15 and 0.23 cpc
any ideas as to what this could be expected that another circuit had been doubled up in fuse however all three cables seem to be part of same ring main.
hi guys
Not enough info mate
You have an interconnection of some description, are all three pair of indentical appearance ? Sometimes you get a older or newer looking one, start as you would with a good ring, end to ends then do a figure of eight test on the sockets see if one pair give you equal readings, record the readings as you go or your get lost .
J
Look at the general board install, if most of the cables all look of a similar installation date, and one sticks out like a sore thumb...well...that's a starter for ten, there is only one figure of eight test for ring mains...it's in the OSG as well as GN3
J
Is the resistance between cables 1 and 2 (the higher resistance values of the ring final circuit) to the 3rd cable the same. it sounds like you have a ring then from one socket/spur and extra cable has been returned to the board.
Reply to ring main in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Very technical :D
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
