Ring main | on ElectriciansForums
Discuss Ring main in the UK Electrical Forum area at ElectriciansForums.net
E
eckersecker
Testing a consumer unit with horizontal trunking above it. On investigation trunking has been used to extend the cables into CU. The cables are block connected in the trunking to extend them.
Testing the ring continuity, r1, end to end I discover a dead short. 2 legs leave CU to be joined in the same block connector to the 2 legs leaving the trunking for the sockets.
Testing r1 at a socket it's obviously Ok. The ring is complete it just does not start in the CU. Is this Ok?
For it to be a correct ring main it must start and end in the consumer unit,
personnally i use push in connectors to extend wiring in consumer unit if needed, smaller than connection blocks/or choc block, try looking at the link to line junction boxes they have the cheapest push in connectors, also senate do them "Ideal" have now released some lovely little orange ones brill in board as take up no room cable in each end, take up to 2.5mm so most wiring.
Anyway ring must start and end at board otherwise the first bit is a radial circuit and could overload
Is a lollipop ring not allowed? Even if the lead-in part is (for example) 6mm? Daz
fog;736373 Anyway ring must start and end at board otherwise the first bit is a radial circuit and could overload[/QUOTE said:
Surely not if appropriate sized conductors are used, it sounds like when the CU was changed they didn't extend the individual conductors and just connected them together, op did you try getting your readings from after the connector block?
"line" do them as well, yellow. cable in each end. just a little bit bulkier than a through crimp. lubbly jubbly.
I meant directly after the connector block, disconnect from there and took the end to ends. Sounds like what I mentioned earlier mate but could be wrong, the individual conductors should have been extended back into the CU to maintain a complete ring. But tbh if it's a 2 x 2.5mm radial for a really short run above the CU it's probably not that big a deal, as they can carry enough amps and like the others have said, giving a lollipop ring
Reply to Ring main in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
Very technical :D
